Lumix Tether not listed (anymore) in Sources/Capture Devices
inzieye
Post by inzieye »
Hello,
I was using my Lumix cam with Resolume through Lumix Tether on my previous computer and I've just tried to do it on the new one and the Lumix Tether is not listed in the sources.
Do you know if I do something wrong?
Thank you
(Was on MacBook Pro Retina and now on MacBook Pro M1)
Re: Lumix Tether not listed (anymore) in Sources/Capture Devices
Does the driver for it have ARM support?
inzieye
Post by inzieye »
Hello Zoltán,
I've contacted Panasonic and the problem comes from their app. The new version has broken the possibility to use the camera as a webcam. Hope they will fix it.
all the best,
