how to make boarders for projection mapping
vj8k3
Post by vj8k3 »
Any tips or trick for projection mapping the boarders of surfaces? I want to be able to change the boarders of these triangles to different clips then the center. I think it will add more visual complexity. I was also going to paint them silver rather then gray to distinguish the difference.
I also wanted to switch in-between having the image duplicated to it being the 4 triangles cut out.
https://www.youtube.com/shorts/rXL_SrpQBX4
any ideas?
thanks
👮♟ ş𝕄𝕆ⓚᗴ ℂяⓐ℃k 卄AιĹ 𝓈ΔⓉ𝒶Ň 😎
Asus pro duo
Intell cor I7
16 gig ram
Gforce rtx 2060
mouse
Re: how to make boarders for projection mapping
Like a Slice outline?
You can make one with Wire.
