Are VST's from Waves compatible with Avenue in MacOS Ventura?
aaronrrc
Post by aaronrrc »
I'm trying to load Playlist Rider VST from waves, but it doesn't show up on audio effects, log:
Attempting to load VST: /Library/Audio/Plug-Ins/VST/WaveShell1-VST 13.0.vst
the same thing with another plugins like Roth-Air, RoughRider3
These VST's are working perfectly on Windows 10 and the same version of Avenue (7.13.2 rev 17774, 23 sep 2022)
Any help is appreciated!
Re: Are VST's from Waves compatible with Avenue in MacOS Ventura?
Did you point your vst folder to the waveshells location?
aaronrrc
Post by aaronrrc »
Yes, I tried different paths, I attached Screenshots:
Captura de pantalla 2022-11-22 a la(s) 8.41.47 a.m..png (12.28 KiB) Viewed 3699 times
Captura de pantalla 2022-11-22 a la(s) 8.41.39 a.m..png (11.42 KiB) Viewed 3699 times
Do you have ARM version of those effects?
Maybe try running Resolume in Intel mode. Right click on App icon, show info, check run using Rosetta.
aaronrrc
Post by aaronrrc »
I suppose yes, I have ARM versions, since all my Waves plugins are versions 13 and 14 and they say in this website that from v13 they have Native M1 Compatibility with ARM Silicon computers:
https://www.waves.com/v13
I tried opening with Rosseta, but when Avenue is opening it crashes, I attached crash report, and ther Avenue Log:
Resolume Avenue log copia.txt.zip
(16.09 KiB) Downloaded 261 times
Crash Report.txt.zip
(16.57 KiB) Downloaded 294 times
aaronrrc
Post by aaronrrc »
Hey, I opened another composition with Rosetta enabled, now works perfect, Thank you very much for your help!
