Send duplicate midi signals to a pc controling quickshow lasers
alexandremix
Post by alexandremix »
Is there a way to be able to pick cues "effects" on the laser running on another computer while using resolume or the same midi controller ?
I want to be able to control the laser when performing on resolume . A way to have my midi controller signals being replicated over a network to the other pc would work as well . This way I would have some buttons just for the lasers and the others to resolume . Or even have some buttons that work on lasers and resolume at the same time . Thanks for the help
Re: Send duplicate midi signals to a pc controling quickshow lasers
Sure, set up midi shortcuts for the outputs:
https://resolume.com/support/en/midi-shortcuts
