stop playing
dvj010
stop playing
Post by dvj010 »
The certain clips stop playing after a few loops by it self.
The files are mp4(h264), 1920*1080 and the length is like 5 seconds or so.
Some play again if I click them, but some just won't play ever again.
Exactly same profile as all the other lips that play and loop fine.
Does anyone have or had same problem and possibly the solustion?
The machine spec:
Mac Book Pro 16inch 2019
CPU: 2.3 GHz 8coreintel Core i9
Memory: 16 GB 2667MHz DDR4
Graphic: AMD Radeon Pro 5500M 4GB/ Intel UHD Graphics 630 1536 MB
juicewon
Re: stop playing
Post by juicewon »
Have you tried converting to DXV?
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
