Option to add Clip time remaining on an output slice
Intange
Post by Intange »
Would love to have the option to add "Clip time remaining on an output slice". That way you could have an output just showing the Clip time remaining. All the shows im doing there are multi view displays everywhere showing all of my outputs. Right now I can have up to 12 outputs. It would be nice to have it set up where everybody can see time remaining including the stage manager who always has a multiview showing all sources.
Re: Option to add Clip time remaining on an output slice
Intange
Post by Intange »
Hey Zoltan,
This is a little clunky. You have it to add it to every clip and remap so its not on the clip itself. I like my idea better, lol. Just a check mark on an output slice "Clip time remaining" for whatever clip is playing. Just like it works now but only on an output slice. Im sure its asking a lot. Just a thought.
+1 for a spout and ndi ouput option of the current time reamaining ui window
Intange wrote: Tue Jan 10, 2023 16:51 This is a little clunky. You have it to add it to every clip and remap so its not on the clip itself.
Effect presets help a lot there ;)
Atreius
Post by Atreius »
Arvol wrote: Tue Jan 10, 2023 22:46 +1 for a spout and ndi ouput option of the current time reamaining ui window
Hi zoltan, this is the best idea, based on my experience.
The possibility of being able to give the signal to anyone in a network is fundamental in this case.
And i believe that in an advanced software like resolume Arena you don’t have to install a plugin, which in any case would use a layer.
A flag would be enough to activate or deactivate the NDI output on that function.
It would also be fine in low resolution to reduce the bandwith involved, for example a 720p
fernando.jp
Post by fernando.jp »
Maybe a slice that could be played in the advanced output. That way I wouldn't spend processing an NDI just for a text
kman1898
Post by kman1898 »
Plus one for this. Would be so nice to have.
edwin
Post by edwin »
One idea would be to add Clip Time, System Time as a variables you can add to the Text Animator and Text Block effects. That way you create your own layout and format and route that to a Slice.
edwin wrote: Tue Sep 24, 2024 18:35 One idea would be to add Clip Time, System Time as a variables you can add to the Text Animator and Text Block effects. That way you create your own layout and format and route that to a Slice.
Would be great to have a NDI/Spout output toggle option in the cog wheel of the clip time remaining panel. Being able to send that out via NDI would solve 90% of the requests I get at award shows.
