Can I link a midi button to make it trigger next/previous clip?
allenissuperme1
Post by allenissuperme1 »
On the keyboard shortcut, we can use left/right arrow to make trigger the next/previous clip in a seleceted layer. Can we do the same thing on a midi controller?
I tried a lot ways and can not make it. Can anyone help? :| :| :|
Re: Can I link a midi button to make it trigger next/previous clip?
Yes, map the same item in Midi mapping.
allenissuperme1
Zoltán wrote: Thu Jan 12, 2023 10:14 Yes, map the same item in Midi mapping.
Hi Zoltán, thank you so much for reply.
Do you mind show me where is the item link in the Resolume window, I can not find it. As long as I can find that "next clip" butto, I believe I can link it to my midi keyborad.
Thank you so much!
Scratchpole
Post by Scratchpole »
Go to view menu and then show layer transition controls, they are hidden by default.
You will now see the previous/next clip arrows for each layer appear to the left of your first column.
allenissuperme1
Scratchpole wrote: Fri Jan 13, 2023 02:45 Go to view menu and then show layer transition controls, they are hidden by default.
Thank you so much! you saved my life :D :D :D :D
