feedback Akai APC mini MK2
I recently purchased the new AKAI APC mini MK2 controller, since it had the first version and I really liked how it works. In the second version I have observed that the lighting of the buttons depends on the output channel that reaches the midi controller. The problem comes when the midi order is assigned to channel 1 and the lighting is assigned to channel 7 when the button is pressed. Does anyone know how to solve this?
rodrigocompres
Re: feedback Akai APC mini MK2
To use this MIDI controller, press the shift and drum buttons, then proceed to map your controller in this "drum mode". Every time you connect the controller, switch to drum mode to use it.
