Scale UI Resolume
Max Mugen
Scale UI Resolume
Post by Max Mugen »
how is it possible to change the scale of the global UI of resolume ?
now the UI is too big for me, and I'd like to scale it to my preferences, regardless of native display resolution
Is it possible ?
Re: Scale UI Resolume
Resolume follows the display scaling you set in Windows.
luizinho
Post by luizinho »
If it's macOS, you can use SwitchResX (https://www.madrau.com/). It allows you to configure a resolution for each application individually.
