Weird audio problem
Nimrod
Weird audio problem
Post by Nimrod »
I moved from Avenue 4 to Arena 7 and now I have a weird problem: audio jumps from left speaker to the right speaker and back constantly with every video clip I tried (it's not a file problem). I tried to switch to mono and the sound volume now goes up and down. I reinstalled the program but the problem remains. Any idea what's the cause of it? With Avenue 4 no problem at all.
Nimrod
Re: Weird audio problem
An animation on a PAN parameter?
Nimrod
Post by Nimrod »
Sorry I don't understand your question
Do you have a pan parameter animated somewhere? that would make the audio go from left to right to left...
Nimrod
Post by Nimrod »
I'll check. It's important to note this happens also on mp3 and WAV files, not only videos.
Does it also happen if you create a new composition and use the wav file in that?
Nimrod
Post by Nimrod »
Yes.
Nimrod
Post by Nimrod »
Nimrod wrote: Mon Feb 27, 2023 19:48 Hi,
Nimrod
It worked! Thanks!!!
What worked?
New composition?
