When I configure my screens to a display containing one or more slice, the output put get flicker after sometimes.
Sometimes the individual slice in the screen flicker.
Dxv3 converted flies also showing same issues.
I changed the fps, 30, 50, 60hz
Bpm 120 set
Tried Re installed old resolume version 7.12
My system configuration
Aurus master motherboard
I9 9th gen
32gb ram
Asus tuf rtx 4070ti
Latest graphic driver
When the windows is running the 2 3 displays its not flickering, software like WATCHOUT, kommander, running smoothly, problem only with resolume
In old days my graphic card was msi rtx 2080
No issues with that, but i changed to asus tuf series
Like 4090 4070ti fliker issues
Output slice flickering
Re: Output slice flickering
Having the exact same issue with the flicker over time although it looks like something to do with only Resolume and my video card because the SDI output from my Decklink works fine.
My system is:
ASUS STRIX Z690-E
i9 12900K
32GB RAM
GeForce RTX 3070 Ti
BM Decklink SDI 4k (about to change to Duo 2)
One DP port from the video card goes to the main board which is the backdrop to the stage.
One DP port from the video card is split between the side screens.
BM Decklink going to hanging center screen.
I haven't been able to duplicate the issue. So far it seems to be at random.
My system is:
ASUS STRIX Z690-E
i9 12900K
32GB RAM
GeForce RTX 3070 Ti
Latest Studio or Gaming driver?
Does it flicker when you open other windows or items in Windows? If so, make sure Peek is turned off.
Im using studio driver latest from gefore experience.
I have the flickering issue when i stay only in resolume,
And when i open any other software like crome, folder, tasksmanager etc,
Also can u help me how to turn off the peek
Check out the video of output flickering
One screen
Two slices
One screen
Two slices
- Attachments
- resolume-output-flickering.zip
- (7.28 MiB) Downloaded 863 times
To me this looks like the processor is glitching out.
How long is your cable run?
Do you see the same on a monitor connected to the machine directly with a short cable?
Its not about any cable or processor issue,
It happen in monitor also. Only while using resolume. In other software like kommander, WATCHOUT, vmix, normal dual display its not happenin.
Which monitor?
A display connected to the GPU with a short cable or your Resolume UI / composition monitor?
I connected both monitors to asus rtx 4070ti with short hdmi cable. Monitor 1- benq monitor 2 asus, the monitor which i output the resolume output is flickering not the ui.
