Request. Transitions cycled clip(self-transition) and (Paused-clip)->(autopilot clip)
Mike79
Post by Mike79 »
Hello!
For a very long time I can not find the possibility of transition of a looped clip to itself with the specified delay interval(same feature as Touchdesigner's MovieFileIn OP, LoopCrossfade Property). This would make it easier to work with non-looped footage.
There is also an issue with crossfading when using autopilot: the first clip starts the transition at the end of the clip (it should be [EndTime]-[TransitionTime]). This makes it impossible to use autopilot with smooth transitions between clips with autopilot feature.
Thanks in advance.
