Option for confirmation box on clip/column trigger
Vjgoose
Post by Vjgoose »
Would be an amazing feature for a number of shows I do.
An option in layer/column submenu to require confirmation upon triggering/clearing. There are times when you have to adjust on the fly and accidentally triggering a big reveal is a real showkiller. Could just default the yes to enter or something. Just make it require two presses when enabled. Could set a specific clip to ignore the setting as well. Like ignore column trigger option. Quite literally messed up a large show last weekend.
Amazing?..
Re: Option for confirmation box on clip/column trigger
Yes interesting, we have the option to lock the content playing in a layer to prevent stopping content but there is indeed no safetynet to prevent actually playing content.
You could make a wire patch and load the video in there instead of arena, and in the wire patch you make a button that then plays the video. This way when you trigger the clip in arena you then have to first press a button to play the video. This makes it a two step process.
