Open then close crash reports
El_Brono
Post by El_Brono »
Hi all,
I have a problem with my 7.13.2 version of Arena.
Each time that i close then open Resolume, a popup appears telling me that the sotware didn't quit normaly (like it crashed the last time i closed it)
I always use the normal quit way to close the soft.
Fortunately,
when the soft is open, It never crashed during a show but I would prefer finding why this problem comes before knowing a crash situation.
One month ago, I did update MOJAVE to CATALINA but it doesn't change anything.
It runs now on Mac OSX Catalina on a MacBook pro 2017 (2 two thunderbolt ports) and I use RAZER X CHROMA + XFX AMD 580 RX.
And I'm thinking that updating MacOS to Big Sur will make the computer slower.
Several times, I use the SEND button on the popup..
I hope that someone there could help me.
Thank you all
Bruno
Re: Open then close crash reports
Exit crashes are usually nothing to worry about, we're looking into a few of them.
Please fill out the email address field in the popup, so we know which report came from you ;)
