During a show recording from inside Arena, Arena froze and I had to force quit the app and I'm now looking at a 7.9 GB videofile that can't be opened.
Luckily I chose the generic Motion JPEG codec
There are many tools that promise to repair broken video but which one you distinguished pixels pushers think is best?
I have no problem paying for a good tool.
Best tool to repair broken video.
RichVisuals
Re: Best tool to repair broken video. and CRASH
Also need a solution after recording crashed mid live set at a festival.
Unable to provide the crash report as there was no internet running at the time and I was playing to a rather large crowd, but it seemed to happen when recording and clearing another recorded clip from the composition.
I did find this link previously but it appears that the company has stopped allowing downloads.
viewtopic.php?t=10672
File is saved with about 20GB of data in it but is currently unreadable.
The crash completely froze the machine.
Acer Zenbook 15in Pro Duo - i9 10980HK RTX3070
UPDATE: Found that Wondershare Video Repair will actually do the repair as long as you have another video recording from Resolume using the same configuration (resolution, codec..)
https://repairit.wondershare.com/video-repair.html and fairly cheap for a month.
