Ideas for Arena working with Denon
The1nOnlyFIRE
Post by The1nOnlyFIRE »
It seems to be the only feature at all is that if the song already has a video chosen for it it will pull up that video and play it but what if I wanted to use the layered compositions or other stuff what about if the song isn't prepped you should at least have it be able to immediately import the BPM and other information from songs loaded on the Denon so if your using layers you already have it synced to the bpm really the link can pull enough information that you should be able to set up automation based on the music basically changes to different things on 1 layer or all the layers at transitions in songs and stuff like that maybe every so many beats changes just one of the 3 layers then on transition or drops and stuff changes all 3 at once also maybe its possible if you already running soundswitch on the denon since that uses dmx to tell the lights and lasers what to do thru automation maybe it can pull from that and have it control it thru dmx
Re: Ideas for Arena working with Denon
got a headache reading this at line 3.
