MIDI Shortcuts
kcstratslinger
MIDI Shortcuts
I keep running into an issue where I am trying to edit MIDI triggers sent from my DAW. If I'm trying to create a new trigger from the snare, I solo out the snare track in the DAW. Then, in Arena, I press Shortcuts/Edit MIDI. It works great. The problem arises when it comes time to work on the kick drum. I go through the same process as the snare drum. It seems to work. Until I realize that when you press Edit MIDI it remembers the last control you had selected. So, I end up accidently changing a snare trigger to a kick trigger. Many times, this has caused me to have to track down the trigger that I accidently changed. In worse case scenarios I have just decided to delete everything and start over. Because I have so many commands it seems easier than digging through everything to find where I messed up. I am requesting there to be an option to have everything deselected each time you enter the Edit MIDI mode. If this already exists, then I haven't found the option.
