Pioneer pro dj link compatibility
puchi
Post by puchi »
Not sure if this is the right place to bring this up but here I go
I'm planning to use resolume arena with my pioneer gear but currently deciding on a mixer to buy.
In the quick guide it states all the compatible units which is pretty straight forward but I'm wondering wether this is a "either this or that" unit case or wether all models need to be supported.
The supported models according to the list are:
CDJ-3000
CDJ-2000NXS2
DJM-V10
DJM-V10-LF
DJM-900NXS2
Now my question is wether the bridge will work with several, let's say 2x CDJ-3000 units (compatible) and a DJM 750 MK2 mixer unit (non compatible, according to list).
Re: Pioneer pro dj link compatibility
Clips will play in Arena, but you won't have the fader data, so all the videos will play at full/manual opacity.
Might work good enough using the Add blend and layers at 50%
