Resolume arena crash
Sari
Post by Sari »
Hello, I hope you're having a good day whoever is reading this.
I work at a venue and we have large screens setup with Resolume Arena,
For some odd reason the application keeps crashing and we have to re-open it again and sometimes when re-opening it we get a chunk of the clips on the computer monitor and also on the large monitors the clip cuts in half.
It would be nice to know what is causing the application to close by itself.
Here is the crash log:
Resolume Arena 5.1.4 rev56521
Log started: 10 May 2023 10:41:34am
Logging has started
Operating system: Windows 7
OS 64 bit: Yes
CPU vendor: GenuineIntel
CPU speed: 3278MHz
Number of CPUs: 12
Memory size: 16222MB
System language is: he
ApplicationPath: C:\Program Files (x86)\Resolume Arena 5.1.4
MediaPath: C:\Program Files (x86)\Resolume Arena 5.1.4\media
CompositionsPath: C:\Users\admin\Documents\Resolume Arena 5\compositions
UserPresetsPath: C:\Users\admin\Documents\Resolume Arena 5\presets
DefaultPresetsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\default\presets
PreferencesPath: C:\Users\admin\Documents\Resolume Arena 5\preferences
UserDataPath: C:\Users\admin\AppData\Roaming\Resolume Arena 5
CommonDataPath: C:\ProgramData\Resolume Arena 5
CommonDocumentsPath: C:\Users\Public\Documents\Resolume Arena 5
DefaultDataPath: C:\Program Files (x86)\Resolume Arena 5.1.4\default
UserDocumentsPath: C:\Users\admin\Documents\Resolume Arena 5
ApplicationVideoEffectsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx
ApplicationAudioEffectsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx
Registration valid
Id valid
Serial has not expired
Instantiate midi controller
Instantiate OSC controller
Instantiate DMX controller
Create ApplicationParameterCollection
Create PropertyCollection
Create and initialise composition state object
CompState::init: initialise GlEngineState
GlEngineState::init: start
GlEngineState::init: end
Create application lookups
Create file loader
Start loading application settings
Enumerating DeckLink Devices
Enumerating DirectShow Devices
Set Language
Hello = Hello
Looking for unicode font
Unicode font is set to - Lucida Sans Unicode
Language file font setting: FontToRenderThisLanguageInWin
Language file font base height setting: 0.00
Instantiate help controller
Load HelpController file
Loading help file, path: C:\Program Files (x86)\Resolume Arena 5.1.4\docs\help\English.xml
Load contextual shortcuts from disk
PropertyCollection, check for user configured keyboard shortcuts
PropertyCollection, no user configured keyboard shortcuts found
PropertyCollection, midi file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualMidiShortcuts.xml
PropertyCollection, dmx file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualDmxShortcuts.xml
PropertyCollection, osc file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualOscShortcuts.xml
Initialize quicktime
Quicktime could not be intialized, is it installed?
Create application controller
Create playback controller
Create audio/video plugin collection
Create composition object
Create video engine
Generic PnP Monitor NVIDIA GeForce GTX 1060 6GB {1930B283-F74F-11EA-9C3D-D3325E681C94
AOC 2270W NVIDIA GeForce GTX 1060 6GB {1930B283-F74F-11EA-9C3D-D3325E681C94
Create audio engine
Load Advanced ScreenSetup Library
Advanced Screensetup library, load dll: C:\Program Files (x86)\Resolume Arena 5.1.4\ScreenSetup.dll
Advanced Screensetup library, Load message:
Advanced Screensetup library, set Application name and initialise
Setup Interface Advanced Screensetup library
Advanced Screensetup library, Connect to Composition
Advanced Screensetup library, Connect to DmxController
Create GUI
Mainwindow: create main component
Mainwindow: setup command manager
Mainwindow: create menu
Mainwindow: enumerate displays
Mainwindow: set bounds and resize limits
Move splash window to front
Video engine is enabled
GUI is present, call initGL on main window
OpenGLCanvas: New context is created
Initialise composition object
Initialise audio engine
Opening DirectSound device: Primary Sound Driver
Opening DirectSound device: Primary Sound Capture Driver
Opening DirectSound device: Line In (Blackmagic Intensity Pro 4K Audio)
Opening ASIO device: Blackmagic Audio
Opening ASIO device: UMC ASIO Driver
Opening Dummy device: Dummy Output Device
Opening Dummy device: Dummy Input Device
Find audio plugins and add them to the plugin collection
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Bitcrusher.dll
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Distortion.dll
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume EQ-3.dll
Creating VST instance: Resolume EQ-3
Initialising VST: Resolume EQ-3
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Flanger.dll
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume High-Pass.dll
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Low-Pass.dll
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass
Initialise video engine
Init glew succeeded
---Info main OpenGL renderer---
Vendor : NVIDIA Corporation
Model: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
OpenGL version: 4.6.0 NVIDIA 516.94
OpenGL version short: 4.6
OpenGL shader language version: 4.60 NVIDIA
GLEW_EXT_framebuffer_object supported
framebuffer_object enabled
GLEW_ARB_texture_non_power_of_two supported
texture_non_power_of_two enabled
Find video plugins and add them to the plugin collection
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGL3dPixels.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLAddSubtract.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLB&WMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLBrightnessContrast.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLColorize.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLColourPass.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCreateAlphaChannel.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCrop.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCubeMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCubeTiles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCut.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDelayRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDisplaceMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDotScreen.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFeedback.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFlip.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFreeze.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLGradients.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLGrid.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLInvertRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLJitterBug.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLLumaWaves.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMask50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMetaMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMirrorQuad.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixLoRez.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixMultiTask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixShiftRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixToBlack.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixToWhite.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLNoisy.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLNoisyMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLParticles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLParticleSystem.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPartsMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPixelHighPass.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPointGrid.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPolarKaleido.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPolkaDot.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRadar.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRotateXMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRotateYMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLShiftRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSideBySide.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSnow.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSolidColor.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSolidColorEffect.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSparkles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLStaticMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLStingySphere.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLThreshold.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTiledMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTimeSwitcher.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTint.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTrails.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTriangulate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTwitch.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTwitchMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControl.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControlCrop.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControlMask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeDown.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeLeft.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeRadial.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeRight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeUp.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLZoomMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLZoomMixerOut.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAdd.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAdd50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAlpha.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBarShift.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBlow.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBlur.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBurn.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLChromaKey.dll
Registering plugin license.
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLCircles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDarken.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDifference.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDifferenceInverse.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDistortion.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDodge.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLEdgeDetection.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLExposure.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLFishEye.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHardLight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHeat.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHueRotate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLKaleidoscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLevels.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLighten.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLighten50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLorez.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaDisplace.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaIsAlpha.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaKey.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaKeyInverse.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMirror.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMixRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMultiply.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLPosterize.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLPremultiplier.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLRGBASwitch.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSaturation.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLScreen.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSetMask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSlide.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSoftLight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSqueeze.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStatic-source.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStatic.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStopMotion.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStroboscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStrobosope-effect.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSubtract.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSubtract50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLTile.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLTwirl.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLWaveWarp.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\InfiniteZoom.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\Lines.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\LineScape.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Colourise.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Fragment.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Goo.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Iterate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Kaleidoscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_RadialBlur.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Ripples.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Stripper.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Tunnel.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_VideoWall.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Vignette.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\Terrain.dll
Advanced Screensetup library, Initialise
Start file loader, if autoload directories are present they will be loaded now
Mainwindow, update lists
Updating Composition lists
Updating Effects lists
Updating Video Effects list
Updating Audio Effects list
Updating Sources lists
Enumerating Capture Devices
Enumerating FFGL Sources
Enumerating Spout Sources
Start composition
Begin GlEngine start
End GlEngine start
Start osc controller
Start playback controller
Initialise midi controller, start devices
Select first column
Select first layer
Select first clip
Select first deck
Show all settings
Show composition settings panel
Delete splashWindow
Startup sequence completed
Open last used composition
End GlEngine start
CaptureDeviceManager::getDevice: Intensity Pro 4K 1
OUT OF MEMORY, closing application.
Re: Resolume arena crash
logs says right at the end
Lots of still images in the composition?
