Triplehead2go projectors no signal
Gmag20
Post by Gmag20 »
I have a Lenovo with Ryzen 5.
One triplehead2go
3 x Optoma eh415st projectors.
Laptop has 1 hdmi output which is connected to the triplehead2go through an adaptor display port.
Gxm is able to communicate with the projectors as the make and model is detected.
Issue is all 3 show “no signal detected “
I’m at a complete loss and would take any help I can.
Re: Triplehead2go projectors no signal
Are you sending a supported format to the projectors?
He2neg
Post by He2neg »
maybe a hdcp issue... you can try to switch this off inside the gfx settings...
~Berlin~
Hi Gmag20,
you wrote that you are using an Hdmi to Displayport adapter/adapter cable.
This signal direction (HDMI>DP) will only work if you are using an "active" Adapter.
May you share the adapter model you are trying to use?
Best wishes
