Resolume Hang on Load - Only into bigger comps - MBP M2 Max
legofsalmon
Post by legofsalmon »
Hey all,
Just got a weird one.
Resolume has been hanging when loading a comp I've been using and iterating on for the past week or so. It's got some effects and some fairly decent sized clips in it (couple of gig each), and it's a decent size comp too but nothing strange.
Anyone had any difficulties with this? Any solutions/workarounds?
I've renamed the comp so it doesn't autoload (I was stuck in a crash on startup loop there for a bit), but would love to get back into that comp so I can start to use it again.
Spec
MBP M2 Max
64GB RAM
MacOS 13.3
Arena 7.15
Have a crash report if anyone can tell me what format it needs to be (tried .txt, .rtf and .pdf and the forum attachments settings don't allow them).
Thanks all!
Re: Resolume Hang on Load - Only into bigger comps - MBP M2 Max
Is it hanging or crashing?
All files used DXV?
