different Fade in in same layer
Balle1011
Post by Balle1011 »
Hello!
I use resolume to show different pictures during a concert.
I want to fade in the pictures. I Know how to do it as effect in the layer. But i would like to use different tempo or effects to slide in during the layer. I hope you can help me.
Thanks in Advance and greetings from Germany :)
Balle
Re: different Fade in in same layer
Effects on clips with animated params to timeline, with param set to play one and hold, could do what you'd like about different effecting, but a bit of work to set up.
https://resolume.com/support/en/parameter-animation
