Hi
I recieved the spec sheet for a gig and there are multiple pixel maps.
Page one is for a main screen that is aligned to the top left of the frame on the pixel map.
And page two is for two more screens that are aligned to the centre of the frame on the pixel map.
Does this mean I need to output two lines of signal from Resolume? One for each seperate pixel map?
managing pixel maps
Re: managing pixel maps
In general I would say yes. The event-location may have two separate led controllers.
But, if those two pixel maps are "not" overlapping "if" they where in one signal container you can just split your signal with a splitter 1:2 and you are good to go.
If they are overlapping you have two options:
1. Send two independent signals
2. Ask the technical head of led if he can adjust the mapping that way that it would fit in one signal container so you can split your single signal. (In best case you should make him a drawing how to place the panels in the mapping including pixel counts)
Best wishes
Best wishes
Do you like outlines? Easy Outliner on Juicebar Re: managing pixel maps
If they sent 2 maps, then yes, you will need 2 outputs.
Bryson Greyser
Thanks for your help
