[Arena] Export a Clips' Start/End Settings
HyperlightDrifter
Post by HyperlightDrifter »
I'm want to open my Resolume Arena Project in another PC.
Everything worked fine, however the changes I made on the Start/End positions of my clips didn't transfer as I opened the Session in the other PC. Other stuff like Clip Speed however did transfer.
Is End/Start Position not saved on the .avc file, or is there anything else I need to transfer to the other PC in order for those settings to appear in the session?
Re: [Arena] Export a Clips' Start/End Settings
Which Resolume versions?
HyperlightDrifter
Zoltán wrote: Mon Jul 10, 2023 09:46 Which Resolume versions?
Mine is 7.14.2. I sent the Project to someone with 7.5.0 installed.
Going back in versions, things getting broken is actually expected, and I think we have fixed something about file readers a while back, which might produce different durations on different systems, causing Resolume think the file changed, and such resetting the in/out points.
HyperlightDrifter
Oh I see, so I guess there's no solution other than updating/sharing between same versions?
Well, you might get better result going to a newer than 7.5 version, but other stuff might be broken.
If you make a backup of the Documents/Resolume Arena folder on the target machine, install the version your license works with, and use your serial to register, you'd be able to revert the machine to the old license and configs/docs after the show is done.
