I have a bunch of intro videos I play, and then I want to jump straight in and switch like 5 clips on different layers in one go.
It's easy to e.g. trigger a different clip on the same layer when one clip finishes. But how do I do many different actions with one go?
How do I jump to a lot of new clips all in one go?
booshtukka
Re: How do I jump to a lot of new clips all in one go?
If you click on the Column name up at the top, and if all of your clips are in that same column, it will trigger them all at once.
