Resolume Arena startup
Gojo
Post by Gojo »
Hi all, so I create startup for Arena to run and play a specific column of media when pc is on. Problem is when the pc is boot up first time and the Resolume run automatically, this specific column is not trigger even I already save and run the column in fullscreen before shutting down the pc. I already turn on the TRIGGER FIRST CLIP ON LOAD.
Re: Resolume Arena startup
If you set all of your layers to "play first clip on load" then column 1 should start playing when the app opens up.
