Trigger random clip between specific columns
rawdesigns
Post by rawdesigns »
So I have 3 layers and set my clips from slow, medium, fast. I use a solid color source, set opacity to transparent and set to play random clip. I was wondering if it’s possible to trigger said random clip but only clips between specific columns (ie play random clip between columns 5-27)
Re: Trigger random clip between specific columns
With Wire and a OSC Loopback you should be able to. How do you want it to perform? When current selected clip ends, it picks a new random clip? or Do you just want a 'Go' button that does this for you?
rawdesigns
I would like to select a random clip each time I click my transparent solid color source and have it play any random clip between specific columns and ability to change the range of columns when needed
Not possible with Arena atm.
Here's the Random Clip Select patch I'm selling for Wire (I added in a min/max). You will need an OSC Loopback using something like Chataigne.
