Saved Keyboard Shortcuts not shown in dropdown
Prav
Post by Prav »
Hi forum,
I saved a number of keyboard shortcut sets, but only default is shown in de dropdown menu. This default set of shortcuts is empty, and even if I copy the XML contents from my other shortcut sets, there are no shortcuts loaded into Resolume. All the XML files are present in the Documents -> Resolume Avenue -> Shortcuts -> Keyboard folder. I have tried altering the ActivePresets.xml folder as mentioned in viewtopic.php?t=17068, but this doesn't work.
Also, the default MIDI shortcut sets are not shown in Resolume, only default, which is empty as well.
I am using Resolume Avenue 7.16.0
Screenshot 2023-08-27 at 04.33.09.png (25.34 KiB) Viewed 4779 times
Re: Saved Keyboard Shortcuts not shown in dropdown
Where did these presets come from?
Could you zip and attach them so we can check them out?
Prav
Post by Prav »
The default.xml was already there.
The other ones I created myself. Defaultttt and TESTTES for testing purposes. The other three are from events where I performed with Resolume.
Shortcuts.zip
(18.91 KiB) Downloaded 204 times
Thanks, they show up fine for me.
Check the file permissions, maybe that's preventing Resolume to read them.
Képernyőfotó 2023-09-29 - 10.25.50.png (77.87 KiB) Viewed 4670 times
Prav
Post by Prav »
The permissions seem to be in order
How about OS privacy settings?
Resolume allowed to read the Documents folder?
Prav
Post by Prav »
This fixed it! Many many thanks!!
