fading between columns?
irisresolume
Post by irisresolume »
I remember that in resolumn when i moved between columns, the default was a dissolve transition
now, it is a cut
i cannot seems to find how to do a dissolve as a default between all columns
i went to the composition panel, and in the crossfader dropdown i chose "Fade (Legacy)" [why would u not give a fade option that isnt Legacy??]
but it does not have any effect
Help :(
Re: fading between columns?
Try adding some transition time to the layers: https://resolume.com/support/en/layers#layer-transition
I don't recall transition times were defaulted to non zero.
irisresolume
thanks Zoltan,
found it. the transition button wasnt there, had to tick the view>show layer transition control to see it.
