Subfolders in Avenue
headphonic
Post by headphonic »
at this point i have a couple of hundred Wire sources that ive built, which makes the sources panel in avenue extremely long. Is there any way to use subfolders so that i can organize my mess? Ive noticed that when using folders in the actual file save location, avenue just ignores them.
Re: Subfolders in Avenue
Doing something like
move Documents/Resolume Wire/Patches/patchfolder/patch.wire
to Documents/Resolume Wire/Patches/subfolder/patchfolder/patch.wire works for me on my mac
How are you trying to do the folder structure?
Or do you mean you'd like subfolders in the effects panel inside Resolume?
headphonic
when browsing "wire sources" in the source panel in avenue, i would like to be able to further organize my sources, as i have ALOT. So being able to break them up into subfolders inside the panel would be super handy.
right now the structure for me on PC is Documents/Resolume Wire/Patches/patch.wire
if i do any kind of Documents/Resolume Wire/Patches/subfolder/patch.wire the folder does not show up in the panel.
moved to feature requests ;)
