Column keeps changing without input
mfoust
Post by mfoust »
Not sure how to properly describe my issue. We have a 3 output setup of the latest resolume running and for some reason it has decided that it really likes Column 2. Even if we launch a new show and don't touch it, at a random interval of between 30-60 seconds it will go to column 2. Has anybody encountered this problem before? We have tried updating the software, we have tried reinstalling it and it keeps happening.
Re: Column keeps changing without input
Does column 2 get also selected in the UI?
If so, I'd say it's probably an external input.
Check the OSC, Midi and DMX inputs, in the preferences with the small play button on top right for signal and the Shortcuts, for mapped controls.
mfoust
Post by mfoust »
We don't have any external controllers setup for the machine beyond a keyboard and mouse. Yes column 2 gets selected in the UI. The MIDI preferences aren't showing any traffic.
mfoust
Post by mfoust »
Here's a quick video of what it's doing. Always to column 2 (unless we remove all columns then it just parks on 1)
https://drive.google.com/file/d/15YRR8x ... drive_link
video is private
mfoust
Post by mfoust »
Check Midi, OSC and DMX preferences, disable all inputs. Also disable Webserver.
mfoust
Post by mfoust »
It appears that all those are off, attached pictures to verify. The only things plugged into the machine are the video outputs, network and a kvm.
edit, nevermind, the board doesn't like my photo size or something...
kvm, hmm, that could behave weird.
Can you try disconnecting it and connecting the keyboard and mouse directly to the machine?
