Performance tanking when outputting to 230 Universes
wongjyitung
Post by wongjyitung »
Hi Tech Gurus,
Urgent help needed here
Have a project outputting to 400+ led batons which amount to 230 universes
The system was put together by someone else who has built the mapping file on a macbook pro with an M1 chip which runs perfectly fine
The problem is the moment i copy the mapping file an open it on a windows machine the performance absolutely tanks to about 4fps, even on a blank showfile
are there any window specific settings to help optimise it that I might have been missing?
Any help or advice would be very much appreciated!
Best regards
Nick
Re: Performance tanking when outputting to 230 Universes
What kind of windows machine, which GPU does it have?
wongjyitung
Hi Zoltan
the problem is solved, autospan seemed to be causing the issue
splitting up the fixtures to separate lumaverses solved the performance issue
I'm guessing that it is a bug and not an actual software bottleneck?
We tested on various servers that had I5 I7 and I9 processors and all had the same issue
No problems on macbook pros with M1 and M2 chips
Best regards
Nick
ok, but what kind of GPU?
wongjyitung
Was running on multiple different machines, 3080 (laptop), 3080TI, 3090
tried on an m2 and m1pro macbook pro as well which did not have the issues
Could you share a composition and an advanced output preset so we can compare with that on our machines?
