Resolume stuck on loading composition and swtiching deck
vejas
Post by vejas »
Hi there I have two questions:
- first one, I create a composiotion on Resolume 7.17.3 on windows, i save it, close the program, when i open it again, it gets stuck like it has a lot of clip to load, which it has not now, because it do it the same even with only one clip, 50mb, dvx (used as test).
The only workaround it's to end the task from task manager, move all the composition in the resolume composition folder and open it again, it now open a blank one and it opens without issues (except that you have to do it again).
The same problem appears when you switch deck, the three defaults at opening, two of them are empty and the first when it's loaded with the same upper clip (the same happens if there is no clips at all), and when you switch back to the first one the loading bar appears on the clip (until the column number 9), of course no clip where previously loaded.
any thoughts?
Re: Resolume stuck on loading composition and swtiching deck
Fils synced to dropbox?
Do you have an audio device selected in preferences?
vejas
Post by vejas »
No dropbox for sure because it's not even installed.
The audio device is not selected I mean it's selected on no output / no input device.
Can you try selecting an audio device?
vejas
Post by vejas »
Sorry but it took so long but I wasn’t in the club where resolume is running, i selected an audio device and the problem still occurring, but not all the time, I would say 1 of 3, so we reinstall the so and resolume from zero and not everything is fine now.
Thank you so much
ok, could you please send us the Resolume log file via the feedback tab in preferences after a hang?
