increase FPS in sand resolume Nvidia A4000
gthdrags
Post by gthdrags »
Good afternoon, I have a server with an AMD Ryzen Threadripper 12-core processor, 32GB RAM, gfx 1 nvidia A4000, gfx 2 NVS 810.
When I use the 8 outputs in 1080p it only gives me 22 fps, how can I increase the FPS in video playback?
Re: increase FPS in sand resolume Nvidia A4000
Use only the renderer GPU outputs viewtopic.php?t=15035
Those NVS cards will never give you what you're after. Try using an 8 channel SDI output card instead and a beefy GPU for rendering.
