Hardware gamepads (joysticks etc) as controller for Arena
bj888rn
Post by bj888rn »
Hello,
Beginner Resolume Arena user and visual artist here.
I have a question for a live visual setup, concerning older controllers.
For my live visuals, I run a bunch of analog gear and digital up and down the wires, but for the live performance, I would love to have some visual gimmicks. I have nice MIDI controllers; APC40 mk2, Korg nanokontrol 2 and some Arturia stuff, BUT I would love to have cheesy live gimmicks as older hardware gamepads, joysticks, etc.
Is there a good way to map old analog gamepads/controllers to control parameters in Resolume? Excuse my ignorance, I'm here to learn! :-)
Cheers!
tijnisfijn
Re: Hardware gamepads (joysticks etc) as controller for Arena
Post by tijnisfijn »
hi that's definitely possible but you'll need to have some software to translate the game control commands into midi, OSC, or you could even make them into keystrokes. If you have that, then you can assign them to shortcuts. There is a lot of different software that can do the transition. The first ones I found on Google:
https://controllerlab.io/
https://miditrol.com/
But there are many more, really depending on your needs, machine and maybe wallet ;)
Hope this gets you going
bj888rn
Post by bj888rn »
tijnisfijn wrote: Wed Oct 18, 2023 02:47 hi that's definitely possible but you'll need to have some software to translate the game control commands into midi, OSC, or you could even make them into keystrokes. If you have that, then you can assign them to shortcuts. There is a lot of different software that can do the transition. The first ones I found on Google:
Thank you so much friend! I will dive into this! :D
I've used Chataigne for this a few years back. worked great. Converted a rockband guitar into osc
