Previous OS version my Resolume Run smoothly but after the update I'm facing some issues like FPS drops continuously and cpu usage also
Please help me to fix this issue
After the update I uninstalled the old Resolume and Installed it again but that is also not helped.
Video link : https://sendgb.com/fBYykEMXQPz
Specifications
MacBook Pro M2 Max
Memory 32 GB
MacOS Sonoma version 14.0
After Updated macOS Sonoma my Laptop Cpu facing some issue
Manikandan
Re: After Updated macOS Sonoma my Laptop Cpu facing some issue
I don't see issues in your recording.
The auto pilot triggers your next clip and the previewed clip is stopped.
Manikandan
Please check the bottom of the video that CPU usage suddenly going 30 and suddenly going 0
Open the activity monitor and check apps there, it will give you a better overview of what happens on the system.
