Output Sync problems
jose
Post by jose »
Hi, i'm workong on a Big show with resolume, and i'm experiencing a extrange problem with a Big led screen. We are using different slices to map It correctly. The problema is that when we play a video, we can see the unions of the slices like there are not in Sync. This comes from same graphic Cars output (quadro p2200) and same led electronic (novastar vx1000) . But if we opem the advanced output, this problem dissapears directly. Any idea?
Re: Output Sync problems
Are the Quadro outputs synced?
One LED processor or multiple?
jose
Post by jose »
two led processors for the screen, but the sync problem is between slices, doesn´t mind if it is same processor or not. this dissapears with the advance output windows open.
about output sync, what do you mean? is not supposed that all the outputs on a same quadro card are in sync always?
Do you see slices going out on the same output not in sync also?
How are the slices getting their input? Layers routed or the composition?
jose wrote: Wed Oct 25, 2023 14:14 about output sync, what do you mean? is not supposed that all the outputs on a same quadro card are in sync always?
sync can be disabled
