Render/Record Output Transformation
Vulpine909
Post by Vulpine909 »
is there a possibility to render a video-file including the output transformation? I want to play the file on a media player without laptop and like to include the warping.
Thanks.
Re: Render/Record Output Transformation
Yes, record the screen.
Vulpine909
Thanks for your answer - but I don't see these record options. View > Show Recordings doesn't show up in my menu. I am using Arena 7.
When I am recording, the output transformation is ignored.
Recording Screens is pretty new.
Which arena 7.x.x version are you using?
Vulpine909
It's Arena 7.5.0 rev77960
Ok, that version can't record outputs yet.
The latest would be able to.
Alternatively, an external recording solution could work.
Vulpine909
And with the new version is ist possible to record the effects of masks in the advanced output, too?
Christoph
Post by Christoph »
Yes with the latest version (since version 7.17) you can select an output screen and record the same signal that you send to your output including all warping and masking.
https://resolume.com/blog/22724
Vulpine909
This is a really nice function: So one last question: Does the clip renderer in the new version also include warping and masks or is it working on the single clip only; including effects etc.?
Christoph
Post by Christoph »
The clip renderer only renders a clip, it does not include any layer/group/composition or advanced output modifications.
