Frame Drop - only when outputting, can't breach 30.
camdencastellano
Post by camdencastellano »
Hi all,
Weird issue having here that just started this last weekend... When I plug into my external monitor & output to that monitor, my frames instantly drop to 30. The only way to bring back up to 60 is if I open any application and have the window of that application OVER Resolume. If I minimize or close that application, drops down to 30 again.
*notes*
- if I disable output to virtual, frames go back to 60, if I unplug fully, frames at ~110.
- monitor I use is capable and set to 60hz, can even go up to 75 (have used it many times without any issues)
- on the NP9371W Sager, RTX4090, 64gb DDR5, beefed up etc etc.
- hardware stats 22% of ram, 9% of vram
- composition is 4k, clips are 4k, yes I created a brand new comp, issue still persists
- newest NVIDIA driver downloaded (10/31, version 546.01)
- have arena set to high performance, high priority, and have processor scheduling in my computer to programs
- peek is disabled
- switched out hdmi cables
any advice is lovely, let me know if you need any other info!
thanks in advance.
Re: Frame Drop - only when outputting, can't breach 30.
camdencastellano
Zoltán wrote: Mon Nov 06, 2023 13:29 this might help
https://www.technipages.com/windows-10- ... ound-apps/
Hey Zoltan!
Apricate the reply, however, I have already done this, aforementioned where I already have my processor scheduling set to programs.
Any other solutions you might know?
Thanks much!
If you enable show display info in Resolume output menu, and send an output to the external monitor,
what do the Renderer and GFX card lines say on the output?
