MIDI and DMX shortcuts lost
hybernia2023
Post by hybernia2023 »
Hi all Masters of Resolume!
I have an issue with shortcuts sometimes, maybe Im doing something wrong
We use DMX and MIDI shortcuts to run our show in theatre to be sync
I have stored presets for multiple shows, anyway sometimes happen, we open a show, and shortcuts are missing (some of them for example).
Is that cause of naming a showfile differently? Or didnt save a show properly?
Im always making a backup of all shortcuts, because Im getting paranoined of losing preprogramed show and have to do it again
Thanks Jiri
Re: MIDI and DMX shortcuts lost
What kind of shortcuts are getting lost?
Are you using different shortcut preset files for your shows, or a shared one?
hybernia2023
Hi Zoltan, thanks for reply
I use different shortcuts presets for each show/play.
F.e. - I open specific showfile, and the presets loaded within file (like 70 midi notes) are missing and there are 4 instead, the same happened with DMX shortcuts
Somehow it overwrite the preset file (opened and checked in notepad)
Maybe when I make new it overwrite the old ones?
But also some of them are ok...really strange thing.
Btw using v.7.13
We're working on an issue where "This.." target shortcuts can get lost in some cases.
Might be what you're running into.
Good news is, it will be fixed in 7.19.
