Resolume Arena 6.1.5 Crashes when Live inputs is connected
DJGkid
Post by DJGkid »
Hi !
before I start this is my pc Spec:
cpu: i7-4930k
mb:asus x79 deluxe edition
8gb ram
ssd: Samsung Evo pro 512gb
gpu: Amd w7100
input card: Datapath VisionSDI2 or Black Magic Design Decklink Duo
compostion 2112x1232px
ouputs: 1x 2560x1440p @60hz straight to LED screen processor(mctrl4k)
1x 1080p@ 60hz to Monitor
inputs: 2x Video processor outputs SDI with a laptop to have video playing
2x ndI input from 2 laptops(pptx)
so I'm doing a test on this setup and from time to time I am having crashes when Input cards are in use or more likely when i have the source clip(which is Inputs from Vision SDi2 or Decklink) on the layer and plugin SDI source to input card and it crashes and sometimes i have the two inputs connected already and i see it working and after few hours of like switching inputs by clicking next column or just trying to simulate a show flow for a conference it just crashes and my composition is not full and not using too many layers because i'm doing a test if it could carry the two output loads i need with two SDI live inputs and a NDI inputs as well. so how can I fix it not to crashes on these kind of set up ?
Re: Resolume Arena 6.1.5 Crashes when Live inputs is connected
Is Resolume allowed to access cameras in the OS privacy settings?
Do you see the crash reporter pop up?
