Hold Oscillator at top of curve
fresnobob71
Post by fresnobob71 »
Hi, I'm new to Wire and was wondering if there is a straightforward way of holding or pausing an oscillator at the top of its curve. I want to slide a rectangle across the screen and hold its position for several bars. I have a little animation experience in After Effects which is more keyframe-based so I have that in my head whenever I try anything! For instance, I have it sliding in using a Curve triggered by an Attack Release but it jumps back to zero where I'd rather it slide in, pause for a few bars, and then slide back.
Cheers, Chris.
tijnisfijn
Re: Hold Oscillator at top of curve
Post by tijnisfijn »
hi maybe this will help you out... just copy and past in to wire....
--begin-wire-patch--
1046.3ocwW0zaiaCD8uRAOKtPjhRhL27m.6kcOzEnGVXTPKQGyVYQuTTdSZf+u2gR9C4XEEi0As4PLEwaFx48lYH4KnLSYoJyoMkUnG99KnUVyFX.O.YpcaqcnEAHmAlQDfzkvDgnE6CNgSbDW3IfjvCHu.HgbkGIzdAF1iKi5cw8S2iOcVYYUgzGS.7EGL8q1bk0GYvDaTNI5gWPxZ2ZCLIBEfxjN0iF6ynGJqKJBP4psElm2nJceSZeT473WBdNacK9R4FEL5OzVE70Nksxud.nMx+x6yTXYzk9QDV.Zqz4MLb+dumqxr5sM6uFWkqq1VHe9KsdDlPmCKqdk1ugQ4wBghjov4wQYXVLmhEgzDLMckJKTEyxy3fME5LUYkZtt3fSNLwYutQpKZGYr5G0kxh6Nx3mhLpOx9QsrP6.JLhxiSBPVUkon1cv70J8iqgUiDxAM9m5bGXGQPCAKqj6Tez6F255MKKOEz01CC1oJyaUc.To5I2WL4pOm2JTkv3Ju6IgMYHNmUur10N2pByO8+5ddqeO07I3OYQs+yJ8i.m5cZSBGtE0IzM+bFMXrz0BtxAga6Jb.qtDRFA0+DbhOfVZpKyqtjJS5vjwAnmPODmj9IXjWEXhOEC1kUHqZLSCAIJMMQjRShwiRlNByHQLrHB9W53zTRBSLaZDiPiXfe3htTNowUlr+FbxNHE03qZLEMT4J3uDYXXyTMAjqYEyps6TCEXIGoqK4UfZNAwmerQ9zaCvuwfbf2F.tg9Vqyg5JnEvQgqiL0UFVbJoaRytuSlzetSWoW5qvb1ZE3SB45rj6QPi4WombJ8fdRSHComyFAcEXoSSvBd7H7X1jQylDQXimmduxnUlqqqFPhf80ELburo1lU7NzI8Z5z2JvXukpIpub5irFcq0joxqsGs3lzUnsmw0b5ys1AnJSVntUvcNc6F4j96bDEdUlFILM81R0DTZLlEFJvhozo334bAelfMYRTT2TM5uPpVqb+5TM54356gAgK5oqQGw5DV+Q4cDjg6wzHCC2ko6UKducX+cbNlB8ptOWopuNK5hrjfKJJNWg8MuWVYraFtHK5dNY6Wu2FmNPus24rpYoyliYBFCymOghmxC4ylExhhlL9d6sc3hkClZzfgLDlgU6yRz7i4Jus9v++Wd7MG7MDtU4QHDSvr47wX9XwTbTBKY5jD9nQIhOD4oS3rzX5Tf2PYuwIOGNK3L2OFL829b4fjunuyy8IH+WbctdN8OhbiR.OAdh.SwiwxPZNNhsRPhWkISYp6UB7MUGt8IYevMTG8Jc5Lq1eoxuuwX.p3sUq8suvn11x1vm05lKcB1aadfGPf3nimogoQPJ9+X7uczugqTEsu70ucH9CtH9BS3JcA9a+6yE7EiPm7+EjG1MKA
--end-wire-patch--
tijnisfijn
if you wanne work with keyframe you can do something like this... hope it helps you... enjoy
3280.3oc6bs1aaibE8uhf9TKfH679Q9lrj8hsn6tnMKPQQZPAszHatghTkjxIYCx+8dmgRhOC0nHmtaBVa.aIp67593bOyK8goqxRSMqJiyRKl9hW8goaxy1BuPOaZ19xc6KQSe8rokYvivnYSiSgGM80eb1IAw3iRVKHYPAQCTkzCRhZKJcv5rLOJsHIx1WaINYftfdvtftmfDndWkkjToBZWsj9cX8v8WUeIINkvZy6ZWmr9cUPurZe9Sl1Bp52UkCMln8G7Pmb89795IZe0pszElAG8CKrqCfaKorujrOoVkx5qqNUwmWsZKde0JU.RlZp0oJq2R7COXxA4d8gZ+mxWCu24u.iNvT.JYJE9zslxnou3CSi1W9XFHwzoP2Opz7PV96m9hz8IIfF0rKI68aMok+bT9ClRq72CNjqdrR9znsF3U+y3bC7tmL4E1QNHz1newVmfRZabp8UX9ro6hJsED8wOZq4hU4w6bZJWUsNtXWRz6+wpZDdP7ZnYi2Da68SWy0ZCdkIXMmtJfwUj.MhHBHxMlUHCmsdkBJSR7JSZg4t3jCUxgGTWqaihSpdUFnphSiRt5Ql5zHiXGY+28QIwkfJjRTbvDkaJxR1Wdn3OZhe3Qn0vHEDB7130kP4vZBBJYQzSlm6dS4i62de5oA897Cu3IS55JqNHTp4ck+X1Zy2uF50PckButvV8XjyCoDbqteeY0y1jj8V6+Ke+Naex8Vn9hR1aeaQ7CfN0VoNuufJoNIs6e0RCENprR3hRX3V0BGjMNEbFAq+Iww1Az8Y6SWWzVUJZnIA+r2M8ELAKTnoBJCQoDDESfm+d6mKCwRDkowDLRSkbnJWkDU3pwXX7OUJEZIQvClKVNOfgor.ME9i7FoDKX5aWRYXBkwERkto0.6pprUuApjm.u2roN7.mVdC7iHBgbOxMVKcsXEF3HiYwQMYaUNn0NIh00Yaz69zBX6Xf6wmVf.ml8w30PHG.Ubzl1vB1zB85S9iKb89FNY+mmhKhu2F7Ulu2.0IF22A5Zr0bUOSsDSCYREQhYJFXPc1YRHQHPDrDhAwbAYDy7syAbDlboHPq3yCtgsX9sKnX1M2IuVqadz538EiX4B4sU7CpjiyWkbFsLouV1Bdjk6S7GwF.9bFUuKOakwlLN4BBsAfxrRW5aewLJVEkX7U3Fzn7TmLLVCQ2yATKTWkCnlP3ALDRGnWRVFvuSoU2pYKVPoMc.IeFNfUNAcc.I0i1Wglgd8.PLMLgmj0RIngYZb.ImwYbHolLaOWObX3oiNVcfp5Yq65a0x2YVqPk53te1VKaxx2NdnG8ZxP94CDpH9ADpQW.Rn716BXZFKPc2BRvRERc6sHFkt3lqEI7.Q2QcYNvxdDYF2Kn1zc2QenQrapm2DSXjrmAIfqTgJfdhPoY7SbPHHcHQJQDJEyYD.9XLVHKVpVDvtUHBTBDMfhv3kLAQiDKt5zSlBSyf9iSdnaDOTh7yv+nnzr6bQ6UU94ZtymODz8kthMh0U225BSvn5sswa5YfQdGYZkzqzO96wPQpPslfUGBeCjv6EHAvYUbdeENWgApLDb.DqqCP2q1DQWKT2yVe0YRxeXucdfiDeZQp69qM2xwhRFon3Y89cnzR8bYdkadpWxerU6tbyp3hQyg8JTHjQt5GP+xTDf54WgOyNbKLl0i4HOrgqUfXqfmC0XS83g.g5nz+QDL+xwScRvWZpSCLq0xmyLmTTUXGSeMgcFAdS.irBAPzjn.z5UQHlACyPT+rj27yEy7.q9lTZbkdx2mNtgYfoSTuvVAqign4hp0N8LniMJkujhZTDuW6f0l24au5j7d6oYE16dBjXZWVONsCli4s4Q61Em9v3x46rfCX7PJRP4JJUx.tEmX.dQK4gb4x.1BMKPKtEd0b9sf7hamKlesIPZrxniA5BwLteHJljwHBJ.pA7lPgRk64BrhSQDIkY+fJYUDLFHGI3xiBSkUeBmPwBnpH1JnplUHMLRwTgUXdUM.LmU.hIhisPn7C0p.nuo4LM7LVUiK0P6xHHo50GcMFgzCB0Y18mr3c8T5GnzONX1mHDrk+bK+0AhLZfOahVONHvULwlGiJBZuhT2mk0XljahRJLGkq0BS0VtCcEuWAgQWjKaLWlaAmKBVY4Pdt.z8owmUFHJ7AS4mQH7PYgHbA38IYBF3BJbgpUSXPxBUHrP.ydSKEiOItkDJGBbEyCtQHvAHx7atkyWHI2cWyPX5yPxndr7GOOTs8txRU6mz0vbRudvHT619CYOYl7xcUzOFw4k8ky48PS7r661pI6IBou+8fNjUJRTPRz8ljFBaou4PdNNf+awoln7oMJxgOwm5Ge95+uuOZsc63VYYaznfmsUv0B6wv312sKK0tQQQIsaHOFO3FCH7k0T+z9xoMK74aqFCKxkNr92+k1sGwi1iTKN0i1C.S5YqndzLzZwY92LsGNLOZGVs37KY3zU0w8ns30hKNeacSzp2zVuI7nMD0hK8rMZOPjdzHxZwUdOP5pwTdzPpZw0dzP.H+JSacl1iVQeRbxkf+zZ33QnScjCA48foci3A3CoF7gfu.cVGyCwCrGRM1C8x.t6zXd.HTiG3AbvKgbPsbC7.InFHf6YCzZH3Q7ec3uv6gPGEkGH.0..dD+a2Cv8IQ4sTVdf.TC.ntfFo0Pwiv+5ne8EMT5nz7.BPeIb3IjeCHwSPpPlfJgYMSYUb0ubN7DASGvht+9f6opMALictjXEkg4W6zv6xge.+xOeV7mgKeatocId1kaYWJicw96hn2EhqKnUWbotXNcgU5hXzETnard2v4tgociD6Ff0MFpaXQOVw8n51iLaOBp8nf1iRYORi8XC1iuWOdb8Xp0i8UO9U83N0icTOhO8n1ziwRONI8XazKQeuL38xQ2Kw6vyQ87GMFBefCsQBLMT6dkbNHqMwIImc4U1jkVFTD+qisO7VD0Ry6JGCx9GhdiYRzjj3hxIYalrKC5RES9Suw79M4vPt3OOIM6sS9k8vGWjs0LI2s1+SRyKl.irIuOa+jUQoS1WXqkeAJ8jxrIaqpzbCLCGaMG9o1lLM6DHKicbiUIcVudLkeAKXOcAdY.SHWFLWRHAn6VvEBNUQkL+Wv90nUXrrC9ZKrSmdcVCiZSSxAaXsay2kmse23dLhuZ7Xrg.1ioZkyh0d6dwmvFS37PhlPPbEFwYBmY8XhUojDJnZF5fYsxC.izjPLWnUDVse.lRB0RpBy0X42nNAxuF1Zaw.GFBIJDC1DqFVoQGIFIfPYIgpoRsRQTXx2j6uMcVue+i829a882V86l82VJt5XuuB2j6IieDvH5uVRm9uNvfBp1SDmNxFaqMUahIEr8EdPgRnD1zlTLFQqNOfG7Pz5PkhBNCRVisdhqfXNv7yQP94uMSnRwewOAmMttQm4nD37itpbuCbvPCXrPIhn3RsDi0X1I..FPalq4DFmJ.tSii.HTZc.atdQfhL+l.MCpMAhRYLzW5iGJ93txyHRolyvHhWGXzl2yqQ2ntVdXcLVyNp9G4Dm9cQkiOaO5uCNmv06yLOTInHgTPD55ClJiBXCXrPynT93GTDvTrHfcm5l.0M5kATASrbgPMe9ye1fgfV8MWvKear8pPMpgg8GG1oeeeXmF5XxBHZHBA.CTMucWP1lPAS6CX1u0mzIRH+.UVDSPIbghM34QBGxpN2RHs8JhPAHvYjPI7Z6O1gpjQwBnrXR2y7z.nlPY0JWQwZjjx.X.JHGucWgJlYu+JcOuT3PZUaPnRjvNQc829mCJJ+JXwaypcQAq1DZWZAHWZAnWZAXWZA3WZADWZAjWZATWZAzWPAR2uMX0iQooljujqqBQx5iEh0gXklBQYTItl4d.ACb6TX.xnBxazcbhJoDX1cqiB.LTSv8BFdMKhoID10lO+fd4LW9mCRg8RJhWRQ8RJlWRw8RJgWRI8RJkWRo895R0lCaKG1gPpFBLZH7lgfTFB0XHfggh8GJ7dnH3gBRqQ0+qYwieD2ohOST8gmfMmOPbIj7MD3mno7iKos6zXKfGB42g.NMFclajmPhj.2D5h.8x6tI.s7NohbiZ4MZ9UFVNzUoq7wbi6xQFa2F2x2ZRdp2EhbWVd4jaLNGsOs5UOzkqy4h8+guO.Ffvn8J2csec.nDqLALihGDgHqAJnazX9lUQRl4ZgHO8EWxn2ftydGJ6er26NQoZSvvSi8kayxJGa9Rer56yh84UlF6ArH1AxCkO280Ihy02ttBJJnlOtthUoj.S.zGYJfM5w8x4WyreWlfBEDFCyHHNmiwLISzdt6uxtcotqLj6x84nk41PL2sUwccNcA0VWO2w+0c.1mY+BrvcGcceSD3VqG2TwcK9maEZcanhaVftqQ+q+3G+esykkKC
--end-wire-patch--
You can stop an oscillator by setting it's frequency to 0. You can also make it go backwards with a negative frequency ;)
fresnobob71
Thanks guys
MarkyMark
Post by MarkyMark »
Increase the amplitude of the oscillator and then use the clamp node the create the "standing still at the edge"-effect with just 2 nodes.
