Bug: hidden group panel reappears after restarting Resolume
SeanBannister
Post by SeanBannister »
Could someone test this to see if it's reproducible. I've created a layout where I've hidden the Group panel... By going to Menu... View... Show Group.
This works fine, the group panel is hidden, however after restarting Resolume the group panel reappears.
There appears to be no way to hide the group panel permanently after restarting Resolume.
Re: Bug: hidden group panel reappears after restarting Resolume
Do you have groups in your composition?
SeanBannister
Yes I do, but this isn't a limiting factor for any other panel, for example you can turn off the layers panel or composition panel and they stay disabled after a restart. In fact I can turn off everything in the view menu except groups.
I think there is a function which enables the group panel if you have groups in the composition, so you don't have to open it manually.
The group panel should be attached to the block of the composition panel, so it shouldn't take up any additional room.
SeanBannister
I run Resolume in a night club environment where DJs are pressing the visuals during their set and I turn off all the panels to minimize what they can break. Here's an screen shot of the interface: https://imgur.com/a/T4JE6So
Up until the group feature was added this was possible. I guess I could add it to the "composition monitor" as an extra panel but its just a shame to have to. Seems odd that I'm forced to have the group panel but none of the other panels?
You can undock panels into separate windows, so it would be possible to have the group panel behind the main Resolume window.
