How to uninstall a wire mixer from Resolume?
SeanBannister
I'm missing something simple here... I installed a Wire Mixer, realised I don't need it and can't figure out how to uninstall it. I've checked in the Effects panel (it's not there) and looked for the file in User/Documents/Resolume/ and User/Documents/Wire/ also can't find it here. Even searched my entire C:\ for the file.... my my search index isn't up to date. Any idea how I can remove this?
tijnisfijn
- Team Resolume
Re: How to uninstall a wire mixer from Resolume?
hi... i would keep it
but there should be a folder resolume wire/patches somewhere, it can also be in your shared user folder.
hope you find it..
hope you find it..
SeanBannister
Haha, thanks a heap for the YouTube tutorial with that patch, was exactly what I needed.
I'm just rebuilding my search index in an attempt to find it, no idea why it's no showing up.
Look in Documents/Resolume Wire/patches
SeanBannister
I just accidentally found it while playing with another Patch in C:\Users\Public\Documents\Resolume Wire\Patches\ whereas I think I was originally looking in MY user directory.
