Wire: Writing MIDI
AcdNrg
Wire: Writing MIDI
Post by AcdNrg »
I read the documentation at https://resolume.com/support/en/wire-midi and struggle with understanding how Wire does pick which MIDI out it is sending on.
It may be just me, since I´m so used to the device/port/channel logic from other programs. so apologies if I didn´t see the obvious...
In Wire MIDI Preferences: I can select/activate multiple devices as output, so let´s say I have an interface with two output ports.
In Wire "Write CC" module, I can select a MIDI channel. But how do I specify which MIDI port/output this gets sent on?
Re: Wire: Writing MIDI
Midi output in Wire sends to the midi devices you enable in preferences.
If the Wire patch is loaded in Resolume, the output will go to the devices enabled in the Resolume preferences.
AcdNrg
Post by AcdNrg »
Understood, so
- wire standalone mode = wire prefs
- wire integrated mode = resolume prefs
So far I see how to enable interfaces for outputs in global preferences (well sort of global, ie global within program context).
I also see how to set the MIDI channel, for example with "Write Note On", pitch, velocity, channel, easy.
But how do I specify which of the two interfaces MIDI is being sent on?
Example:
Wire standalone mode.
Two interfaces activated as outputs, interface A und interface B
Module: Write Note On, channel 1 (set in the side panel), pitch C4, velocity 127
Connected to MIDI Out
Is that note on event sent to
- Interface A
- Interface B
- both?
both
tijnisfijn
Post by tijnisfijn »
Would definitely be nice if you could specify that. That would give you a option to for instants have one controller for arena, and one controller to control wire patches.
