Outlines inside other outlines
pette
Post by pette »
how can I obtain this effect?
So I want to display more outlines inside the slices like the image without make a video, it is possible with resolume effect?
thanks
tijnisfijn
Re: Outlines inside other outlines
Post by tijnisfijn »
hi hi ... Merry Christmas..... the easiest way of doing this would be to use a distance lines node. something like this..... Of course, there are other options as well, but they get a bit more complex. Let me know if this is good for you or if I could help you more.
--begin-wire-patch--
1704.3oc6Z01ahiCD9uRU9LoxuGm9MngJsRm18zcU5jtUnSlDSw6FR3xKrs2p9e+FmDBgRZJ8.sZ6oVj.i4wi8Lyy3YrS+tSXZRhNrvjlj6b0m+tyhrzUPCzHmzxh0kENyF4TjB8fG4XRp53wQsvfNyWpVqaQQ5CE4.gQafQFVZagg2CF+.wI5aVEaggZw40fCsGPuCABq3hklvulnyy2Cq7Pr98JT1AKRYeKR+dm6HSdgJITuu0A0mYLeUZJrTStaOrzCcejViaWYRNb9orcKzYMM+TVjNqRq3if0AB5ektP4b02cTkEKSgeywYjSnpPeWZ1Cv2xSKy.E.zE853zGVoSJtUkcmtvNl4Yf1srdLIpUZn0eXxrn2nyxAtnEzJ0WrxE7NqLI1VXvBtVUXGH5wGsRNOLyrtnBuUTfYacr5gOVKweO1Dpu3WLfO7h4Obwsluj.XLQvJwrvXUGmPlBwPywtHOA2kQBEtpHpu6B4hPlXwbNdAAFiUPI45aLw55IpoilIB5XkxDW2JMybmIQEexJqWqxRrJ6eWphMEfkkRjbfZmoySiKKZF9Rs4tkvrgQRfk7MSTALNrOAAiLWsQeFM8UqlhkkqlmzpzkYMM1nShpIC.nD88EeLMR+gHmq7AYk.syshGUwaJJxLyKKp6ZQb52reV7vZ6Rp5qf3Twk1ulatCLoVYZRpiLx6.1j.rNve1hmaWhySKShx6ZbjjclFJXlt24JAldIlyETeASxndvVKOX+U4kThufijdRejfvA4EFqxqDmATGGOOguGAHMZAdgk4fbkXhxEEEBTJsGiKHcsojJIjF9UXra.NXpMZIMtxVs.9SnPnptpzuh5IpJHbmdlaoc6zxOmTFGOpm2lYU+klHfoCn5XxFUaWm054qCQ9fMtn0i9WaL4l4VldQVoFjD9Pu0o3EHnNtAedkaPhNU2.0Of5xvSjtSld8TWB0ShH2HoS8uoqa.+yfa3P6+hzg8.mP.yRUt6J08cfNOMMdGzlonBlI4kfcTNdqQd+oDVcphm.XuI6I.raakVswdtaHvfJFZ5rfKSLuHFfy0rG3yi5X22.iI8wXo.O9XYrADJjxYrXr6Dg.x.QFOYJmesG4l8Xrzy.i8.q6v6OriMT6l1Qhp8qO02zZZa7C632+YJTkwfLaxgLaPKLPttbnlF2HH0T31jbC4bmaJfBMrtngwsBpPICDOHYnjj75xdGZOLal1nRHf+4hLVnhy0O1MgrqZdUS8ScAjN6ZXSNOxltd19icEjj7kThNvyzwpBylgmpQX6jTU82Qq2uXjPyV2XIWdouvCwvHLjz60u08zwDgKyKP35K4Pz.KfGbMEylbi2oFHzPkTVtzyGOvrRFHrYpNXp6fDsC12cVmk9kszQvphZdsqkamNgnfMF82dFjcA9XGd4SWkrN9Qqiz9Z1nirUqWuiTAcHDHzYp3WeJr9iLGsuYtGhV+gcGR66mY2enUmP91PzNIVsKgK9MnZzJV8yuAD47VbSeAHHH.omha7wGcDBaxuBQHbOpqTo7fpMoBx7PFymhO0haZOo4yFc7YzkHlDU8GC6QnDNPdOu8M6wQGjz5URT6df8A0ED2uZtIDnRTO5nyXWGQEeAM165ykNH0jddolXj3PtI8jO+CSt.AuAmb1mFsvUsPK8krHp.M+rT3M9TnDM2wzIHgcWux.jps6keD9+O.dqr71cNGv6y9O59wGQQrjJuOACd+SJ08joSG6xBnRW4zobWzzIiYWOI.Md5zy8otJz2WTlo6lP15idYK9s0C7hOUVLnAm89Yr945LVzdyaR8PuANhE9G1Qr1lPYPtM+ct8aAtMGIdKb8AWJnLjTfvDICJ64GGW+11J7FhrKNkaWFzb2ZT6x7X+XG5ZqwwykO5hw3rSkSLVD.oiwTFTKF7l2DOOrf4OMfxvDJiK.Ibp4kCKy1L3ETfQ8TLeOwmmZD9djtFOZG+2ndKF35pU+PrGuSj8fNxaXAuc.3Ww.xM+yf1d6SYv9anif9Z6G+h3N1S41+M3+ZHun.t8zD7otRLMv0CIBB3A2LUJCNK0RhFlscvgMdJl9YbUdjsF89n.aMz84s6lE2pKCRLk+uZasWSYb+brsF9M81Z9uus14aasWC488s0FhX17vLr+qhXUIak3lpvw1qiGbBtXg3RD0yGQjTBhhatoBWLlRuzF8y4HOYU2+i8INAknxQLLr6.FyQ9dHF22Ryzws2duiUsrKe6CJwdI6RGaPR0yZ0d0a1yLYKkzVPP0iop5FYl83i+KviXVoZ
--end-wire-patch--
tijnisfijn
Sorry, I didn't read your question correctly you were looking for a solution within Resolume. I made you a little movie how I would do that. And I made the wire example into a little plug-in to play around with enjoy
Slice Line Filler by Tijn.cwired
(12.97 KiB) Downloaded 444 times
Now if we can just get localized mesh rotations. Everything I've tried still rotates the raster.
pette
Post by pette »
tijnisfijn wrote: Tue Dec 26, 2023 13:05 Sorry, I didn't read your question correctly you were looking for a solution within Resolume. I made you a little movie how I would do that. And I made the wire example into a little plug-in to play around with enjoy
Wow! it's fantastic thanks!
So it seem Wire is good but at now I want to use Resolume very well!
But if I want to color with different color the outines, what do you suggest?
thanks!!!
tijnisfijn
hi Pette do you mean a different color for every Slice or a different color for every outline within a slice?
pette
Post by pette »
HI tijnisfijn!
A different color for every outline in slice, so the outermost line white and the inside line red
thanks
