Wire: Manage/Use presets from wire Dashboard?
somnium
Post by somnium »
Is there any way to add/edit/select presets from the wire interface? I've scoured the docs but haven't found anything yet.
While working on a patch, it would be nice to be able to add/remove/select presets. As it is, I'm always having to keep a mental map of what the "default" previously was when I'm tweaking things in effects and I often forget to set it back to the default before saving.
Re: Wire: Manage/Use presets from wire Dashboard?
Coming in the next version! 👍
somnium
Post by somnium »
bart wrote: Tue Dec 26, 2023 18:52 Coming in the next version! 👍
Sweeet!
