Green specks
rawdesigns
Green specks
Post by rawdesigns »
I have a monitor that is getting very very tiny green flashing specks kind of like noise but it’s very subtle. It’s coming from fiber > fiber DVI adapter > DVI. I tried swapping the DVI cable but no luck. Anyone else experience this before?
Re: Green specks
Try lowering the data rate on the cable, lower color depth, or refresh rate.
Could also be external interference.
Re: Green specks
ya, sounds like a bandwidth issue. Had this also before. Additionally there is a chance that you encounter a defective hardware part.... But primary I would also try to lower the bandwidth so see if gets better.
best wishes
Re: Green specks
That's standard with most DVI cables. It's do to poor shielding. I spent a good month back in 2016 comparing about 100 different DVI brands and only about 30% played well with our LED wall.
rawdesigns
Re: Green specks
Thanks for these solutions I will give it a shot!
