I've searched for a while but I can't find info on how to pass Resolume's MIDI clock to Wire.
I thought the MIDI in node would do it ...
Midi clock into Wire
tijnisfijn
- Team Resolume
Re: Midi clock into Wire
You don't need to use the Midi in for that. There are several different notes that you can use. As long as you're building in Wire you can push the play button on top to make that work but if you use these in your wire patches inside of Arena, then they will automatically take the beat from arena....
--begin-wire-patch--
811.3ocsVtraiaCEF9UofqEM38KYmUTDvrYZWDftnHnfVhNls5hqDkSbG328dnjmLFHYLRQlQaDIEO+jmO9SR8ETUeWmuJF56FQ27GOjgBc6mh+5PseXodqO5P27EjaJtqGZCgxPUtn+w9gina5lZZxP098M8Ga8cw6cCO5io9uYv0Usao+ctVOT52CCdn1A+vHLdoN059qjlZXXBcoRTQFZuKlBjb5TR4wpgv93b+SRUGF223N94EEgFB0vvF1FRyWjRukQIUZbMW3vBMUiMlJEVTqjapc0FlgCwzDp7ci9xPyYQN2v2Ts0EZVJ0ODdLz4Z9vYl4kLikxr+Yx0Dh.B4LiTkgF7i8MSwyguyGdbGLZThgjgdJTGg3nVFAhbzcv+id1D2M0to6kjdZ3bgC9t5kUcnSc9mietu1+oZP.FTGJOljmRlcHw3PXyTbossM8OkdGOtOMmlqB54ZlRU8fvQTZj2zO0UOdYNaXWjwxLzyvakckPoUVMUvkRgxngObL4WDzUJgwP3ZJwx0RPxpF23rhAXhhzovXJItzJKvh7RK1JxIXNmqDJYwc2Ud6kzhNqPe0eCwd.bW8ICeeyLE1BOJGgL2T2Xz0EmGn1olXXeyrI7xT1E+VNSSY6tPM3WgcVK.4gWVytGVFG22OD+k6CvPewJxedHLF1jbpwgIOnAk9JZ+lbjRTeWPZnFiPqjJ1YNJElUFfGLAgwEWkiFqpDKtUUfWWJEXNHhnzbGiWXtjij++b7R.81no0eUzn+Q5CAl79MhVIYkkSnZo1PYWgdJMQiEq42hsEk4XRQo1vxME4V4GzE9Z6UBUC9DxFCOmp8ju4f+Mcc49Yu52Gsl2ooiSe+lNJmuRCLjonZp4ZdNkJmBdNlAuVt1hokJvmpJfOm+S1y8ots8WEL1ONXd8wZLiXkUXTDC2Zt91Q.qIzPKw4vNSbYw5bSdt5tBl5mLZ9M3h3qflSKWpMMT8UpLERS+JPmg4+o.P.VxYvFGNWXUymeOm+L.LTgVJYB64yixP+aeeKjGqzLsjHTTJgJ4TqgktSz2r7WLIuuEkrqoSCxRWMMeh4CmN8e..ieqnC
--end-wire-patch--
--end-wire-patch--
