Palette In Node
producation
Palette In Node
In the Wire 7.14 Tutorial (Random Color Generation) you could colorize the Texture with pretty unique Palettes (like in Arena with the Gradient Source) but just from a random generated palette. Is there a way to get user generated Palettes into a Wire patch? As far as I understand the Color In node can only choose between pre generated single color presets. On the other hand the gradient palette can just have a start and end value (besides the static hacky workaround like in the 7.12 Tutorial). It would be nice if it is variable like in the Gradient Source of Arena.
